I need help on hooking up the wires from the molex plug to the head phone jacks.
J is wire or shield? is it soldered to mic jack tip, center or ground?
8 is wire or shield? is it soldered to mic jack tip, center or ground?
K is wire or shield? is it soldered to mic jack tip, center or ground?
H is wire or shield? is it soldered to hd phone jack tip, center or ground?
7 is wire or shield? is it soldered to hd phone jack tip, center or ground?
thanks
fred
not doing Audio control panel nor speaker.
thanks
fred
