For those of you in the primer camp, I'm wondering what you did with the outside of the fuel tanks (i.e.. anywhere that won't be in direct contact with fuel or Proseal). Did you mask and prime before assembly, wait until after assembly, or elect to leave the tanks bare? Any pros/cons/gotchas that you ran into using your chosen treatment? If you primed before assembly, in the areas where a finishing fillet of Proseal is applied (like around the Z-brackets on the tank baffles), did you make sure there was no primer under the fillet, or were you only concerned with keeping primer away from the fay surfaces themselves?
If it's relevant, I'm building an RV-14A, and using Stewart Systems EkoPrime water-based, one-part, primer (perhaps not the best choice to use anywhere near fuel, but, hey, I'm not going to have any leaks
Thanks for any insight you can provide!
