On my return leg home from CO, KAEJ->KUMP, I developed fuel pressure fluctuations that intermittently caused slight engine roughness.
This after solving the oil pressure reading problem on the outbound leg (https://vansairforce.net/threads/low-oil-pressure-reading.229707/).
I have a stock lycoming IO-540-D4A5 from Van's. Just under 500 hours since first flight in 2017, but the engine was delivered well before that (I am not the builder, will have to check records but I think the engine was built/delivered around 2009-2010).
Took off on the R tank. I have the G3X set to remind me every 10 gallons. Typically I turn on the boost pump, switch tanks, then boost off. I switched to the left tank using this procedure, and when the boost pump was turned off FP dropped from 24psi to 14-15psi. I turned the boost back on, pressure came back up. There was a brief period of roughness after a slight delay. Turned the boost pump off, pressure then fluctuated a lot for quite some time (I can post the data), occasionally down into the teens, and then gradually stabilized at 23.1-23.2 with intermittent small drops.
FP did the same with subsequent tank switches, and continued to fluctuate throughout the flight though it was less than after the initial episode.
Back home I pulled the cowl. Externally the fuel pump looks fine. There is no fuel or blue staining from the drain tube or on the belly of the airplane.
This one is not a sensor issue; the engine ran rough, and the FP normalized with boost pump on.
I am looking for suggestions for troubleshooting and what to look for as a cause. Is this a symptom of a failing mech fuel pump?
Thanks in advance.
T.
Thanks in advance.
T.
