Brockster
I am presently drilling the center section of the fuselage and want to install the brackets for the five point harness. Will probably be using a hooker harness. Are the dimensions that vans provides sufficient or should I increase the spacing between the brackets slightly. Vans calls out 1/8 inch. Also for the hooker harness does the through bolt location need to be lowered?Searched a few posts and found where some have done this but wanted more recent opinions. Thanks
