bryanhorgan
Member
I made some changes to my setup and now I have CHT problems (new carb, pmags and baffling). The CHT problems really only exist on the ground if I taxi or sit for an extended period. At top of climb (4000 ft, 110 knots, 85 degree day) I am seeing around 380 degrees CHT. Then after landing, I've got about 7-8 minutes before my CHT's start to hit 400. I let them go to 410 before shutting down. All cylinders are within 10 degrees or so. There is a slow and constant rise in CHT on the ground with seemingly no end in sight. That is at idle and FULL rich.
0-360 with Marvel Carb (10-4164-1) and Pmags. Mag timing was done TDC plus 5 degrees measured from case split, with inclinometer (which should give me 20 degrees BTDC). Jumper wire is installed on the mags. I also recently redid the baffling. I did a backlight test and can't find any leaks in the baffling (I backlit the engine bay with the cowling on and used a borescope to check for light).
I'm all out of ideas and was hoping one of you had some.
