I had many of the slider canopy parts including the rails, fuselage track, handle, and doghouse anodized by the same company near St. Louis that anodizes many (now) Boeing parts. The cost was under $150 and it didn't matter if it was one part or 20 parts because the set-up cost is the same regardless. Available in many colors, the anodized finish holds up very well and is a great alternative to powdercoating. About the only tip I can give you is to make certain the parts to be anodized are blemish free because unlike the masking qualities of a paint coat, any defects in the aluminum will clearly show through anodize.N788RV said:Has anybody looked into anodizing or have any suggestions to protect and spruce up the canopy rails and slidder. I thought anodizing might look nice but not sure how it will wear or if it is too expensive. Any ideas??
I am too cheap.N788RV said:Has anybody looked into anodizing or have any suggestions to protect and spruce up the canopy rails and slidder. I thought anodizing might look nice but not sure how it will wear or if it is too expensive. Any ideas??
Rick6a said:About the only tip I can give you is to make certain the parts to be anodized are blemish free because unlike the masking qualities of a paint coat, any defects in the aluminum will clearly show through anodize.
Same here, works great!! Give 'em your rudder pedals at the same time, no extra charge...$90 was the minimum lot charge (5 years ago).rv6ejguy said:Had my canopy rails and latch hard anodized. No maintenance ever and no dirty black aluminum oxide on your hands or rollers. Highly recommended.
