FORANE
I have a Collins AMR 350 audio panel, SL40 com 1 and Garmin 430 com 2.
When the AMR 350 toggle switches for com 1 and 2 are both set in the headset position, the volume on the Garmin 430 (com 2) is low. When I move the toggle switch for com 1 to off, the Garmin 430 volume immediately increases to an appropriate level. If I set the Garmin 430 com volume to maximum, with both com 1 and com 2 set to headset on the AMR 350, the volume heard in the headset is loud enough to hear well (though nowhere near as loud as it should be).
I replaced the AMR 350 thinking it was bad. The new AMR 350 does the exact same thing as the old AMR 350.
Anyone have any ideas why this is?
