sansoneservices
Worn out subject and I have read the posts regarding the issue.
Yesterday I was in 75% cruise power, peak egt to set mixture, cylinder temps were all around 320°, rpm 2350 and I detected a slight miss with a faint rumble sound (4hr flight). Landed to uncowl/inspect. Pulled top plugs and did a "thumb" compression test. Found nothing wrong, performed high power run-up, took off. Today I used the valve wizard and went straight to the #2 jug.
Ex valve sticking (again)
last year I used a 1/2" ball hone and I'm thinking it wasn't aggressive enough. Apologies for starting another sticky valve thread
