It Begins….Again!
I has been a long time since I posted about my project but I’m happy to say that I received the entire tail kit last Saturday and began work on it immediately. Since most of our workshop has been commandeered by John Stahr, who is painting Paul’s recently completed F-1 Rocket, I decided to put the right wing away for the time being and work on the newly obtained tail as each sub-kit takes up FAR less room than the remaining wing.
First, a few observations on the tail kit.
The box was delivered to our hangar by Catmandu and Karen and sits in front of the completed left wing.
Crate after opening with inventory list sitting on the corner.
Bushing already pushed in!
The only error found in inventorying...mixed size rivets in one partition of the "tackle boxes". Fortunately, the incorrect sized ones are larger and can be cut to the appropriate size.
- The first 20 tail kits ordered were sent out into the wild nearly three weeks earlier than the expected shipping date. Wow! And, apparently, they are “complete” (if one doesn’t expect fiberglass tips at this time). Just the horizontal stab, vertical stab, rudder, and elevators. No tail cone.
- Big thanks to Mike (Catmandu), Karen, and Chris for making the pickup and delivery work! I owe you on the next will call pick-up.
- While a couple folks reported a “defective” rudder skin, apparently they caught the problem before Mike and my kits were released. If the problem is what I suspect it is (16 missing holes), the fix will be SUPER easy and I would have just accepted a template to drill the holes instead of asking for new skins.
- Only one error was found in inventory. Half of the AN470AD4-4.5 were -5.5. Apparently, others have had the same issue (corrupted bin at the factory?). But, it will be easy to cut the -5.5s down to -4.5s. There were also a couple of odd things listed that I don’t think are actual parts but some remnant of computer reliance. We will see, but I don’t think they are real, stand-alone parts.
- Unpacking and inventorying, pretty much alone, took about 3 hours but was interrupted frequently by other shop activities. There are surprisingly few parts!
- The KAIs have changed a bit, probably for the better. A QR code is on the 4th page to direct the builder to the Builder Feedback page. Seems like the drawings are even more detailed than the wing drawings. My favorite, the item numbers remain consistent throughout the Section instead of changing on each page. This will undoubtedly require a little bit of adaptation moving from the Wing KAIs to Tail KAIs since they are done differently, and both work, but it seem to me to be a more logical approach in the Tail KAIs.
- Different from the Wing kit, the Tail kit commonly has some extra rivets and washers. This is a very welcomed change, especially for folks who haven't built before and collected a lot of spar rivets and washers in their workshops.
