Filament Dryer
docjjrmd
Benefactor
Starting to play with some of the more exotic engineering filaments. Besides requiring higher temps, bimetal or stainless nozzles, and enclosures, many suggest drying before use. For example, PPA-CF25 suggests drying at 80-90 C for 4 to 8 hours even if stored in a dehumidified environment.
So I am looking for suggestions for a dryer, what are any of the experts here using?
On my Bambulab X1C ,when printing those filament, I mainly use the Printer itself with the Filament drying function (directly on the heatbed). Then directly back into the AMS.
Bite the bullet and get the big fancy sunluu (if you are going to get into nylon material which I assume you will)
Any knowledge of SOVOL or the CREALITY boxes? Seem similar to each other get to 85 C. The Sunluu looks like a monster at 115 C. At least I'm familiar with the Creality name though never used one of their printers or filaments.
I just use a standard fan-forced oven, monitor the temperature with a laser thermometer. Make sure any cooking residues are removed before use, to avoid contamination.
I have been using a Sunlu S2 for a couple of years. Does the job well. I ended up following some advice from Reddit and printed a piece to fit between the opening in the enclosure to set the angle of the filament leaving the dryer and to leave a small, known opening for moisture-laden air to escape. Would definitely do that again, as out of the box I had issues with the filament tubing getting pulled into the dryer.
heck I just pop mine in the oven. you just have to be sure what the spool material is. I have had the spool melt all over a perfectly fine filament :(
I think the question is why on the exotics at home. I ponder this myself pretty regularly; the cost of the filament, exotic nozzle requirements, high temperature+heated enclosure, pretty specialized print settings and build plates tend to point at outsourcing. Of course, I say all that as a guy with access to Markforged CCF 3D printers, so "outsourcing" means sending to the engineering team with the printers...but I've very very rarely had to do that. I say that as most parts for an RV can be done in ASA or PETG, or PETG-CF (atomic filaments) of you want some additional stiffness/better bonding.
For drying, I use a regular food dehydrator, then print from a sunlu s2 dry-box. Those have some issues with spool as you get towards the end; I've had a few jams as the force of filament feeding exceeds the weight of the spool riding on the bearings, so it moves and jams the unwinding.
Why, just to learn and conquer the challenge, kind of like building airplanes. I could always order out to a 3 d print shop but where's the fun in that!
This did have me hunting on the latest in CCF printing tech. If Fibreseek can deliver on the $3k printer + slicer, its a game changer for hobbyists/airplane builders/small aircraft shops.
I just bought the Creality SpacePi X4. Too early to say for sure if I like it, but first look it's great. I wanted a 4 roll dryer because I just ordered the new Flashforge Creator 5 Pro, the one with the tool changer, and wanted to be able to load everything in a dryer. I was between the that and the Chitu E1. I really liked the Chitu because it moved the screen to the end so it could sit turned so it takes up less space on the counter. I opted against it because the Creality would get to a higher temp and I wanted to dry Nylon and there were reviews that the Chitu case would soften and deform at higher temps. I will say since I got the Creality I REALLY wish it had the screen on the end. It just makes more sense to me so I kinda wish I had taken a chance. Beyond that I have nothing bad to say about the Creality machine.
