I'm preparing my corrosion strategy right now, and attempting to do without any of the bad stuff.
I live in Houston so corrosion is a real threat, I've already seen the untreated practice kits in my garage begin to show signs of corrosion.
My current plan is to apply prekote and ekopoxy for all internal surfaces and parts, but that leaves the exterior vulnerable to corrosion while I build. From what I've read it's not recommended to apply the primer so early to the exterior as you want to top coat soon after.
It seems the best option is to etch and Alodine, but I'm really trying to avoid using any of the chromate based solutions in this build.
I was also thinking maybe there's something like corrosion x that can be applied to exterior on regular intervals while I build, but that also appears to cause problems if you plan to paint later.
