Another update.
Four flights today (Saturday). They’re visible on Flightaware.com if you search 245WM. There may be other sites that track this stuff, but this is the one I’ve been using.
Our goals today were to continue to feel out the performance characteristics of the plane and deal with some minor squawks that needed attention.
Here’s my take-aways from today:
Even though we’re limiting power to 180hp, she’s looking to be about equal to my current RV14 in performance (climb and speed).
I was seeing about 1600 fpm climb with 2-pilots (440 lbs) and 44 gals of fuel. A bit less than my current RV14’s climb rate in similar config.
Single pilot (205 lbs) - my last flight of the day - with about 34 gals of fuel, I saw over 2000 fpm for a brief time (about a min). I didn’t attempt this for a prolonged period as measuring this climb was not my objective. On par with my current RV14.
As for speed - we still have not run at full power other than take-off (she’ll go 100.0 MP, but we’re keeping it to about 90.0 MP). Best speed in level cruise so far was between 165-170 KTAS at 7500’, 65.0 MP, about 2300 rpm. But will likely change a bit as we play with RPM, and certainly with MP. The engine has so much torque, we find dialing back the prop sometimes gives us better speed.
Here’s a sampling of some numbers I noted at different power settings:
5000’ msl, 47 F, 142KTAS (163 mph), 4.2 gph, can’t recall the rpm/MP, 38 mpg
7500’ msl, 47 F, 160 KTAS (184 mph), 6.5 gph, 2350 rpm, 60.0 MP, 28.5 mpg
7500’ msl, 47 F, 160 KTAS (184 mph), 6.2 gph, 2300 rpm, 60.0 MP, 29.8 mpg
7500’ msl, 47 F, 168 KTAS (193 mph), 7.4 gph, 2360 rpm, 65.0 MP, 26.1 mpg
These numbers are just a sampling - don’t read too much into them as we’re not focused on performance data just yet. Nonetheless, I wanted to get some idea of what we could expect performance-wise and share.
All that said, perf numbers are looking pretty good so far. Some related thoughts…
We’re thinking best performance will be about 2250-2300 rpm’s. It appears we actually burn more fuel and lose some speed with higher rpm’s. Likely due to the engine moving out of its peak torque area.
Fuel efficiency is dropping with speed - no surprise there. But, I suspect at higher altitudes very good speed/efficiency will be realized - better even than we have seen already (due to the decreased air density (lower drag) coupled with the forced air system).
That’s it for now other than we may not fly for a few days. We’ve got a small hit list of things to address:
-Cracked wheel pant (shop accident).
-Modify the lower cowl to allow for more cooling air to exit (cowl is ‘ballooning’ a bit - seems we’re taking in inlet air faster than we are evacuating it)
-Tweak to the flaps as the left wing is very slightly heavy
