DeltaHawk for RV-14
Sorry for the lack of postings lately. Been Busy getting ready for Air Venture.
I am flying out tomorrow to meet with the DeltaHawk folks in Racine, and plan to fly the DH Cirrus before heading to Oshkosh. Going to check out their test pilot in my RV14 as well so when he comes out to Eugene for the RV14 DeltaHawk flights he is familiar with the plane.
The DHK200 is currently mounted to the fuselage and the cowling has been fitted. All will be ready to show next week at DeltaHawk's tent. I plan to be at DeltaHawk's tent everyday, and hope to meet some of you then.
Very exciting and lots of progress keep us posted and if you can post any pictures here while you are at Oshkosh that would be greatly appreciate. Good luck. What are your thoughts on the progress being made?
Arrived in Racine Thursday afternoon and after successfully navigating the TFR (Republican Convention) headed directly to DeltaHawk’s hangar. The DeltaHawk/RV14 was already wrapped and loaded on the trailer for the 90 min drive to AirVenture.
Met lots of the folks w DeltaHawk. Very sharpe group. Also met their two test pilots - Danny and Victor. Checked out Danny in my RV14 as he’ll be coming out to Eugene to do the initial few hours on the DH/RV14. Victor is heading the testing on the Velocity. Wish I had recorded its departure to OSH this morning as it sounds awesome.
This morning we did a tour of the DeltaHawk HQ and production facilities (across the field from the hangar). They are working on some interesting things that I am sworn to secrecy on. Nice set-up and more very sharp people.
Dawn (my better half) and I are now kicking back at a marina for lunch overlooking the lake and contemplating our plans for the weekend which will end with us being at AirVenture sometime Monday morning. I’ll post additional updates from there more focused on development news on the engine.
Craig thanks for all the updates, looking forward to some pictures of your plane. Changing the subject, have you given any thoughts on fuel caps. I was looking at the Newton A508L 3” Locking 8 bolt hole and was wondering if the would fit on the wings.
Doubtful, these wings most likely fit the Newton SPRL 66mm aluminum (and plastic) caps which do come in a locking (Not the plastic ones) and non-locking version. Also, Aéroport Products makes a nice aluminum cap but not locking. The Newton A508L I'm pretty sure has an opening for 100LL also. Not sure what cap is needed for Jet A.
Craig with the jet a fuel nozzles don’t we need a bigger opening so I was wondering what you will be using as fuel caps
Unfortunately (?) we had the wings built before the DeltaHawk project gained momentum. So, likely we’ll be using an adaptor for filling the tanks. I’ll get a pic and post it this week (just saw the one the DeltaHawk guys use to fill the Cirrus yesterday). That said, if we have time, we may try to install a dedicated filler orifice - but, bear in mind that whilst the certified guys are only approved for JetA, us experimental guys can burn diesel (as you would in your truck). The nozzles for these also differ from each other. Frankly, I likely won’t have a firm recommendation until I’ve been flying the plane for a bit.
I agree, will have to use an adapter one or the other if you plan to run both JetA and diesel
Settled into Oshkosh finally!
Sunday night I managed to score a nice Airbnb basement within .5 miles of the field, so Dawn and I are not commuting back and forth each day as expected. The airbnb has two bikes so the 1/2 mile is a breeze! All that said, I’m a little disappointed as I was looking forward to exploring a different field each evening and hoping we’d find a gem or two. We did spend the weekend in Madison/Middleton WI and it was great. Reasonable hotel rates and good food. Beautiful area.
On the DeltaHawk front…
Making progress but the plane isn’t as far along as we wanted it to be for AirVenture - some of the parts arrived too late for everything to get bolted on before sending it off to the show. Even less than sharp observers will see from the pics below that the turbo and most of the plumbing isnt attached. After the show, the fuse/engine will head back to Racine for them to finish the install. Synergy will send one of their guys out to get the cowling on proper. I’m estimating we’ll see the whole assembly back to Eugene by about the first week of September. Final assembly will then take about 4-6 weeks and then we’ll begin flying.
Incidentally, when the plane (N245WM) begins flying - we will be in construction on a second DeltaHawk RV14 that will incorporate a few modifications/improvements that should trim a few pounds and allow us to shorten the engine mount 1-2”. I’ll have more on this later.
Random Bits:
I’m lobbying heavily w/DeltaHawk to let us put the 235hp version on the RV10. As good as I think the 200hp DH will be in the RV14, I think the match with the 235 on the RV10 might be even better. Would love to see it on the RV15 as well!
DH says they don’t have a TBO yet but expect it to be 1500-2000 hours initially. They are working to get it ‘on condition’ at some point. Which, is essentially what it is for us non-certified (experimental) folks. Remember, the engine has no valves/lifters, no mags, no spark plugs, and it’s a mechanical fuel injection (no ECU). The parts count is substantially less than the lycoming. But, it does have a supercharger and turbocharger. I am as anxious as everyone else to see what the actual maintenance looks like.
Pics in order:
Pretty nice old VW at the EAA auction this Thursday. Just wanted to share.
Got to sneak into the vendors free beer and food event this evening. Hartzell was the sponsor. My pic doesn’t do it justice.
Battery located rear of baggage compartment in RV14. CG is not an issue. We’re still a bit porky - approx 60lbs over the lycoming install - but we expect to get this down to 20-30lbs. I’m pushing DH on this - and, they understand that useful load is important to us. They’ve got firm solutions for 30lbs as I write this - and, it’s one reason we have a second plane in queue for production (the one we’ll show at OSH next year).
Shot of the panel recently altered by Aerotronics to work with the DeltaHawk engine. The iPhone and ipad aren’t in place so it looks a bit empty.
The last three are some shots of the engine compartment.
Lastly - it was nice meeting a number of you today. I’m at DeltaHawk’s booth everyday this week - just at random hours, but 2-3 hours a day. Looking forward to meeting more of you.
Craig, thank you for your updates. You mentioned a second RV 14 in the queue. I was wondering and hoping it will be a tricycle gear. If so do they have to build it from scratch or do you have another builder like yourself to let DH put the engine on their plane. Great pics enjoy the show.
To calm your concerns about the fuel caps, I offer this: I've got over 1500 hrs flying three different experimental diesels (an RV9, Sportsman, and modified Cessna). All three have the "stock" fuel caps. Most Jet A fuel trucks and pumps have a smaller nozzle option that work just fine with the smaller fuel caps. On the few occasions (mostly in Mexico) where only the large duck-bill nozzles are in use, I simply carry a funnel. Yes, it takes a little longer, but in reality I've only needed the funnel a handful of times over the last 16 years.
Obviously if you can find a larger fuel inlet/cap solution to integrate into your build, that should definitely be pursued. However, If you're retrofitting It does not need to be a huge concern.
Kurt Goodfellow
Thanks Kurt, it’s a new build so I’m going to fine the right fuel caps if not like you said a funnel will work just fine. Have a great night
Folks,
Some interesting stuff to share on the DHK 200 engine project. I had mentioned that when we begin flying the current RV14 project (should be up in the air before the end of October) we will commence building a second RV14 with DeltaHawk. The second plane will have their newest iteration of the DHK 200 with the latest evolution of the engine block. The plan is to complete the no.2 plane while no.1 is accumulating flight data, and tweak things as appropriate. We do know already, though, that the new block will allow is to further stream-line the cowling amongst other things. I have attached photos below of the new engine/block.
The key differences are:
>The Block loses about 13 pounds. You'll notice the slightly smaller flywheel (with lightening holes) and the detail on the top of the block. DeltaHawk says the block is not just lighter, but stronger - and they have been working with a well known engine block manufacturer on this.
>Some of the cooling runs are now internal to the block (as opposed to external plumbing) - which further shaves some weight by cutting down on the external hose runs.
>The engine mount has been modified at the attach points to the engine.
Check out the pictures - there is quite a bit of detail, and this is the version of the engine that will be in the second RV14 as well as for general consumption once the FF package is complete.
The target weight for the entire package is 30 pounds over the installed weight of the Lycoming. This won't be achieved with plane No.1, but the goal is to achieve this for the no.2 plane - which is planned to be flying next spring and then at Oshkosh. The fuselage and much of the air-frame is already complete (thanks Synergy Air), so I believe the time-frame is realistic.
Incidentally, DH is telling me that Engine deliveries will begin mid-2025. They are already taking deposits on positions ($1K secures a position, doable on their website). Also, my understanding is that Van's will allow deductions from their standard kit config for folks building a DeltaHawk version. Regardless, I know DH is speaking with Van's about offering a FF package for the DH engine at some point down the road - that is to say, allowing a Van's kit customer to choose an engine (Lycoming or DeltaHawk) and then Van's will send you all the right stuff (vs buying the non-engine components thru DeltaHawk). I suspect it would be helpful if folks interested in this option would reach out to Van's and express interest in this - my personal take is the more Van's understands the magnitude of interest in the DH engine, the more likely they are to offer the option as a standard choice when ordering a kit.
As long as I am asking folks to pester people - please go on DeltaHawk's sight and vote for which plane you would like to fit the engine to. I have seen a lot of representatives from other GA companies speaking with the DH guys this week, and I dont think it would hurt to make sure they know how many of us RV'ers are interested in this project. Better yet, reserve a slot if your inclined to.
On the RV14A - I know the folks in Synergy Air Atlanta are talking with DH about developing a package for their tricycle gear 14. No timeline yet, but its being discussed. The great thing about Synergy Air is they have many projects in process and can complete builds quickly (and, to an exceptionally high standard). I will keep you posted with any developments on this front.
Lastly, a shout-out to some of the Forum guys I met today at the DeltaHawk booth (tent, not sure what to call it). Collin from Toogoolawah, Queensland, AUS probably wins the kudos for the longest trip. Jason from Atlanta. And, the original poster for this thread - CzeckSix. Thanks for saying hello, and for the interesting feedback.
Random Bits:
Pics in order:
Love to see this project proceed. TBD
I just got home from OSH, spent several hours at the DeltaHawk booth and enjoyed meeting Craig and several of the DH guys. Was going to post some pics but I think Craig already has that covered above. I asked a ton of questions and thought I'd share what I learned for those interested. Disclaimer: I may not have heard everything correctly so no guarantees about the accuracy of this info, and of course it's all subject to change...
The prototype installation on Craig's -14 has a PlanePower alternator and SkyTec starter, but DH has responded to feedback and the production engines will come standard with B&C alternator and starter which is great to hear.
There is ongoing discussion about how far aft the engine can be moved in the RV-14(A) installations, and part of that decision is how much space should be provisioned for the accessory drive pad. From previous history of discussions about the IO-390 I think many (most?) builders have been putting on a backup alternator. A B&C backup is quite a bit larger than the compact MonkWorkz unit...I think the latter would be sufficient for most people and would allow the engine to be moved back a bit (with CG and aesthetic benefits).
I asked whether there was any risk of hydraulic lock given the inverted Vee orientation and was told they did extensive certification testing to prove to the FAA that it isn't an issue.
The Idle Governor is actuated by a solenoid in the fuel control unit. I was told it does not have a failure mode which would lead to engine power loss.
Engine warm up time in summer is typically 5-7 mins before coolant temp reaches the minimum for takeoff power. In winter it will be longer although the Tanis preheater system (which will be included) will help by ensuring the main engine block is already warm.
I inquired about how they avoid excessive piston ring wear around the intake/exhaust ports (keep in mind this is a 2-stroke...no intake/exhaust valves). There are three rings on each piston, the lowest one is an oil control ring that never reaches the ports at TDC. The two upper rings, which do pass thru the region where the ports are located, are pinned to ensure the rings never rotate. This keeps the split in the rings aligned with the portion of the cylinder wall between the intake and exhaust port (otherwise the ends of the rings could catch on the edges of the ports). The ports are chamfered and extensive testing has shown no significant wear on the rings around the edges of the ports.
I asked why the decision to both supercharge and turbocharge the engine. Answer is that the supercharger is important at low RPMs and turbocharger is better at high power settings and also at high altitude. Plus they provide some redundancy as the engine can still run (at reduced power output) on only the supercharger or the turbocharger if one or the other fails.
The supercharger is a twin screw type. One of the screws is driven directly by the serpentine belt. The other screw is driven by a gear from the first screw, and the pair of gears are in their own self-contained gearbox with dedicated gear oil.
The oil pump has three impellers ganged together inside one housing. Two of them are scavenge pumps and the other is the pressure pump.
The mechanical fuel injection, oil pump, turbo- and supercharger are all unique to DH, that is none of them are off-the-shelf from other engines...DH started out earlier in development working with proven components & engineering expertise from other suppliers but the designs have evolved into their own custom solution for the DH engines.
The RV-14 installation brings the exhaust pipe out thru the tunnel area. Exhaust pipe routing on the -14A is still TBD. The DH guy I talked to was thinking about splitting the pipe (after the turbo) to go around the nose gear and then rejoining it in the tunnel. I suggested that it may be simpler/better to use exhaust exit(s) that are NOT in the tunnel similar to what Van's did when they reworked the FWF installation for the IO-390-EXP119...that configuration should work for both the -14 and -14A models, keeping the cowling identical. The tunnel could then retain the stock Van's cover & cowl flap to minimize drag.
The prototype cowl for the -14 has access panels for checking oil, coolant, and oil drain. There is no provision for a cowl flap, that will be evaluated based on flight test data once Craig has the -14 flying.
None of the currently planned DH installations have provision for a muffler, although they acknowledged they'll eventually need to address this for some customers, especially those in Europe. I'm not sure it would be possible to fit a muffler in the RV-14 cowl but would be interested if one was available.
Craig's RV-14 is using a duplex Andair fuel selector. It looked like 3/8" fuel lines for both the supply and return, so when you're building the fwd fuselage you might want to plan accordingly.
The electric boost pump is something DH is still sorting out. The initial plan for the -14 will have it mounted on the hot side of the firewall...I didn't catch the specs, but apparently the boost pump requirements for this engine exceed the capabilities of the typical AFP or Andair boost pumps used in IO-390 installations. I also heard a comment that DH wasn't sure they would keep the boost pump in the long run.
I asked how many hours DH has put on development engines in the test cell...answer was something like ten engines that each have ~5000 hours on them, and most of those hours are running them hard (abusing them). Long term they expect 3000 hr TBO and eventual goal is 'on condition' with no TBO at all. Cylinders have a steel sleeve that can be replaced and of course bearings, pistons/rings, and all of the accessories (fuel control unit, water pump, oil pump, etc) can all be replaced. DH stressed that they do not plan to have a life limit where you essentially throw away the engine and buy a new one.
The engine will still run with a cylinder inop (clogged injector for example). DH has demonstrated that it will run on only two cylinders albeit very rough and with significant power reduction. It will also run for a while after loss of water pump/coolant and they had to demonstrate this during certification testing, so if you have a coolant overtemp alert in flight you would have a decent chance of getting it on the ground at the nearest airport without the engine seizing up.
I asked about oil consumption and was told it's nearly zero...much more like a modern car vs. a typical Lyc/Cont where you're adding a quart every dozen hours (with much of it ending up on the belly). Also asked about oil change interval and DH is still working on a recommended interval, the guy I asked thought they would try to start out around 150 hrs and maybe extend that eventually (start out conservative). Regardless it should be significantly less frequent than the air-cooled engines where we're accustomed to changing oil ever 25-50 hrs.
They will likely recommend a compression check & borescope check (both via the glow plug port) at every annual.
Other maintenance items like replacing the coolant and serpentine belt are also expected to be 'like your car'...very long intervals.
DH has tested engine shutdowns and restarts in flight, both with prop windmilling and after prop has completely stopped. It handles restarts well and there are no complications if you forget to switch tanks and run one dry (i.e. it gracefully handles purging air from the fuel lines in this scenario and restarts quickly).
DH hasn't tested the engine for acro yet and they are wanting to gather data from the RV-14. Structurally the engine mount is designed to handle the RV's ultimate G loads and the engine itself should handle the loads as well but DH was non-committal pending the additional test data. Note that Craig's -14 won't be equipped for inverted fuel/oil but there's nothing inherent about the engine design that would preclude such a setup if you provisioned for the pickups in the fuel & oil tanks.
Propellers: so far Hartzell has tested several instrumented carbon fiber props with the DH engine, the plan is to approve existing propellers and DH does not expect the engine to require a new custom prop design. DH is wanting to get other brands approved as well, especially since Hartzell acquired Whirlwind which removed their main competition with predictable results for the consumer...hopefully MT, Catto, etc will come to the rescue with some competitive alternatives. BTW there are no plans to approve an aluminum prop due to both weight and vibration concerns.
Speaking of props, I got mixed answers from different people at the DH tent about the anticipated RV-14 FWF package & price. One person told me they are targeting $110-120K including the prop, someone else said $110 not including the prop...and if the only option initially is a Hartzell carbon fiber prop, that's another $20-27k depending on the model. Hopefully they can figure out how to contain the cost of the whole package so they don't price themselves out of the Experimental aircraft market.
BTW I also stopped by Van's tent and spoke with Rian and Greg, both confirmed that they will allow the -14(A) finish kit to be customized for builders who want to remove the mount/cowl/etc for the IO-390 (you would get partial credit for the removed items per long-standing policy). Otherwise they aren't budging on customization for the emp/wing/fuse kits (per new policy established during Ch 11). Hopefully at some point Van's will support the DH option in the finish/FWF kits as it would probably be more cost effective than having to delete IO-390 components and then go to DH to get the full FWF package separately. Fingers crossed.
Lastly, Rian noted that DH didn't build any nose-right offset into the engine installation in the -14. This was discussed earlier in this thread, seems there was a disconnect between Van's and DH engineering on that one. So it will be interesting to see how much right rudder is needed to center the ball. I would imagine they will fix this along with other changes to the engine mount and cowl on the second -14 installation that Craig already has in the works.
Catching up after returning from Air Venture...
First, thanks to Mark for the post just above - he nicely details a lot of information. I have a few things to add to what he posted, and I will hit them in the order he brought them up:
>The New Block will be compatible with both the PlanePower/Skytec combo or the B&C starter and alternator.
>Engine warm-up time is about 8 mins in -10 degree weather. In the summer, its about 3-4 mins. This has been tested at DeltaHawks field in Racine, WI. Also, they have had no issues starting the plane down to -20 degrees.
>The engine should not need a cowl flap. The engine is water cooled (and has an oil cooler). Additionally, there is no baffling on the engine (nor plenum) as with the standard Lycoming installation. Air is ducted directly to the heat exchangers from the front of the cowl and will exit the cowling thru fixed openings. The final cowling design is still up in the air - the one we will use on the test plane (the one that was on the engine at Oshkosh) will likely change quite a bit based on flight data and the fact that the 'newer' production block that will be used in the second plane has a smaller flywheel and internally routed coolant lines. This should allow for a more aerodynamic design of the cowling.
>edit<: This is the Newton SPRL V9 duplex valve (not the Andair as I originally indicated - thanks for the catch dmattmul), which likely will be an option.
>The engine off-set will be incorporated into the production version of the mount. The initial tests in my plane has no off-set, but will be adjusted based on the flight test results.
Unrelated to Marks post - we are still planning on having the plane flying by mid-October. Once the fuselage is back at Synergy Air in Oregon (early September), and final assembly begins, I will have much more to post.
My biggest concern with direct injection for aircraft was a viable backup fuel delivery option. I thought GA aircraft would be forever limited to port injection.
A central (common) pump would require an unrealistically large pump motor/amp draw . I've heard of rail pressures as high as 10K psi for some TDI machines. 5K psi at 0.6 GPM (10 GPH) would require 0.5 HP, theoretic so -> over 125 amps before you add for system and component inefficiencies.
Don't know if it's DH's creation or just their application but utilizing individual (pre cylinder), engine driven mechanical pumps is clever. Failure of one pump (or injector for that matter) dramatically changes the criticality level -> mission impact but maintain reasonable safety margins to be able to land safely. Back-up injection would be a possible option but that would be a lot of added complexity and weight. I can't see any way this project could have gone forward (as slow as it was) without their seemingly novel approach.
Kudos for clever thinking.
Edit = Dmatmul caught my GPM vs GPH mistake/ Corrected above.
& shame on me for the wrong flow unit/equation application. I never designed a system with low flow.
Folks,
Craig, one of the best highlights at Oshkosh 24' was meeting you and the DH crew! I brought news of our encounter back to Atlanta and the Synergy South crew is ready for all possibilities. In fact John, another 14A Synergy South builder, and I are looking to be the first -14As flying under DH power. Let's keep the conversation going -Jason
Jason,
Great to meet you, too. It was also for me one of the best parts of AV meeting many of the folks on this thread (I thought about posting pics - but, decided not to as I figured many may want to keep their privacy).
Craig
Thanks for the interview Craig. I'm excited about your RV14 and look forward seeing how it performs. As many here are aware, I built an RV9 with a Wilksch 2 stroke diesel and flew it for years. I loved the sound, the economy, simplicity, and safety. If the DH performs as promised, you will too!. If it goes well, I'm working on an airframe now that would be a perfect match for the DHK235, and would love to give one a try.
It should be noted that the DH is not really "supercharged" in the sense that you might think. The blower is there primarily to scavenge the cylinders. Without it, the engine will not start or idle. All 2 stroke diesels have some type of scavenging blower and are considered "normally asperated" that way. Add turbo boost to make more power. As Aaron indicates, as long as it's running and producing boost, the turbo will keep the engine running. And of course if the turbo goes away, the blower will keep the engine running, albeit at lower power.
Aaron also mentioned that this engine is different from Detroit Diesel 2-strokes. He is partially right. The "modern" Detroits had poppet valves for exhaust ("uniflow" scavenged), but back in the '50s Detroit Diesel did build a line of fully ported diesels, the "51" series (Loop scavenged). I owned a 4-51 (in-line 4 cyl) at one time. They were used primarily in boats, medium duty trucks, stationary power units, and generators. Just some trivia for you...
If you ever want to discuss 2-stroke aerodiesels or just aerodiesels in general, just send me a PM. I now have over 1500 hours flying experimental diesels.
Kurt Goodfellow
I interviewed Aaron, one of DeltaHawks engineers, at Air Venture. If you can get past the low-skill set of the interviewer, there some useful info in this.
DeltaHawk interview
As you may have contacts there, I'll reply to you.
I've mentioned before that their approach for the fuel system was clever. It removed a rather large obstacle for safe incorporation of TDI in my opinion. I'd still be interested in some of the details. The pumps obviously have to be positive displacement type to supply the required pressure. In the video, I believe he mentions a related cam lobe. Can I assume that the individual pumps are piston/plunger type? Anyway of finding out? Thx.
@kgood
Can you explain a bit more on what you mean about the supercharger is for scavenging only? I know from DH PR that the supercharger is used for start, in-air restart (stopped prop) and idle. Turbo is everything else.
My very limited understanding is the supercharger like the turbocharger is used to increase the incoming pressure into the engine to increase available air/power.
Tim
Thanks for this explanation! I couldn't previously understand why they did a blower and turbo.
@kgood
Tim
As we know, a 4-stroke has a dedicated stroke to scavenge the cylinder (the exhaust stroke). A two stroke does not have that luxury. When the piston is at bottom of the "power" stroke, the row of ports around the bottom of the cylinder is exposed (one side is intake, the other side is exhaust), and the blower sends air into the intake ports. The air "loops" up into the cylinder, and down to the exhaust ports and out the exhaust. As the piston starts the next "power" stroke, the ports are then covered up by the piston and are therefore "closed". I hope that makes sense.
This is different than a 2 stoke gasoline engine. Gas engines use the downstroke of the piston to provide scavenging air to the cylinder. As the piston travels down, the bottom side of it creates pressure in the crankcase that will scavenge the cylinder. That's why mixed gas is required in 2 stroke gas engines; pressurized oil lubrication isn't possible in this configuration.
When most people hear the words "supercharger" or "turbocharger", they think "boost" or "more air" = more power, as you've indicated. In the case of a 2 stroke diesel, the turbocharger is the only thing providing boost and "more power". The blower is just providing intake air and exhaust scavenging for start up and idle (and in non-turbo 2 strokes, it provides all the air for the engine). As you can see, I prefer the word "blower" over "supercharger", because it's industry standard, and it's more accurate.
I did not see the DH PR that you refer to. It is correct - the blower (supercharger) is required for starting and idling, since the turbo is not making positive pressure until it spools up. Another option for a 2 stroke diesel would be to use an electric assist turbo rather than a mechanically driven blower. This way the turbo would take care of both duties (providing scavenging air and boost). I've not seen this done yet, but it seems plausible...
I'm a real fan of two stroke diesel engines. While not the cleanest, they are relatively efficient, usually much lighter and simpler. All good things for aircraft.
Hopefully this info is helpful.
Kurt
Kurt
It is replies like Kurt's, above, which make this discussion forum enjoyable, informative, educative and thought-provoking. This thread, I believe, embodies the true spirit of amateur-built aviation. We see participants here who demonstrate not only significant technical expertise but also genuine enthusiasm for a technology. It's worth pointing out that, while we're talking about a single brand of engine, much of this discussion is focused around brand-agnostic technologies.
I don't have a horse in this race but have a genuine interest in diesel-powered aviation. The little fantasy scenario that runs in my mind is building an RV15 with a diesel engine which I could use to explore the more remote areas of Canada where avgas is a scarce commodity. I thank all those who have provided valuable contributions here. I thank you for keeping my dreams and enthusiasm alive!
Kurt
I hope I'm not drifting the thread too much but I'm learning a ton here. My question is, would a tuned exhaust like we run on dirtbikes and sleds benefit a diesel similarly? Probably a hill to far, but maybe tuned for the very low rpm at startup so the supercharger could be eliminated?
@kgood
Yes it does. Thanks. The DH PR was in a DH video a while back, I think with AvWeb around the time the engine was certified, but not going to swear to it. And after spending 15 minutes or so, looking I am giving up. :D Not really critical I think to find it.
@Canadian_JOY @Jjackh10 I agree.
Tim
Ive been a two stroke diesel guy since I was just a pup, but I've never heard of anyone developing a "tuned" exhaust system. I cannot see any way such a system could eliminate the need for a blower / supercharger.
Kurt
You can see a pretty good visual depiction of the individual fuel pump plungers driven by a set of two cams starting at 2:18 in this video:
One of the many advantages of this 2-stroke design is that the fuel pump cams are driven directly off the back end of the crankshaft with no gears required (like you'd need if it was a 4-stroke with fuel injected every other rotation). Beautiful simplicity.
No. Dirtbikes, snowmobiles (and 2 stroke model airplane engines) use the descending piston to pressurize the crankcase and when the exhaust and intake ports at the bottom of the stroke open, the pressure in the crankcase forces the new air/fuel charge into the cylinder as the exhaust gasses escape on the opposite side through the exhaust ports. Thus, a tuned exhaust pipe helps extract the exhaust gasses (at the tuned pipe speed primarily). In a DH engine, the geared blower serves the purpose of introducing the new air charge into the cylinder via the intake ports at the bottom of the stroke.
I figured it wouldn't substitute for startup. But I'd think it could help add hp at the desired RPM.
My apologies for the slight drift. Also apologies if it's a dumb question.
Watched the vid. Looked at the pix. Understand the need for the higher torque config for a "standard" aircraft starter.
That said, during a start - turning that slowly with very high of a CR. How do you keep the beast from kicking back?
I reached out to one of the engineers at DeltaHawk and this was his reply:
The high pressure fuel pump is a plunger style pump.
There is a fuel cam that controls engine timing and other aspects of the pump. ( very complex stuff have a team of 2-3 engineers dedicated to just the fuel system)
There’s also an engine driven gear pump, the delivery fuel pump. This pump delivers fuel from the tank to the high pressure fuel pump.
Hope this is useful,
Craig
It's not a gas engine - fuel is injected at just the right moment for combustion - early ignition isn't possible.
My guess - speak softly of nice things. At least that seems to work with my cows!;)
I'll ask the DH guys next time I speak with them.
Hi Mark
With regard to the piston ring arrangement, if the oil control rings do not pass the ports, how is the upper part of the cylinder lubricated?
Hi Mark
Maybe they do it with Diesel oil..... A modern 2 stroke runs on an oil ratio to gas of 50 to 1, with no crankcase oil.
DH does not add oil to the fuel. That much I am fairly positive about. As for how lubrication is provided, sorry I do not understand how DH does it, although I have seen some information on it.
Tim
Craig
What I'd thought and the gear pump makes sense. The plunger type typically don't have the "pick-up" that a gead pump would That and the gear pump is probably lower and/or arranged to always havea flooded inlet.
Gas(oline) engine has nothing to do with it. The AF mixture typically has some time to mix before reaching detonation conditions or being spark ignited. Looked back at some of their available info. They're injecting at TDC or essentially into a fully compressed vessel which wouldn't be without its challenges; achieving a somewhat homogeneous mixture being one of them. It would make for some interesting combustion dynamics at a minimum. Make me wonder if the associated combustion event takes a little longer to complete versus a CI engine that injects before TDC. Would be monster cool if someone with some specific insight would educate me here.
From a eyeball analysis, this would also seem to be detrimental for unburned hydrocarbon emissions. This is something two strokes already suck at. This will be a probably be a target for anti-aviation types (e.g. leaded fuel now) in the future if this PP gains market share.
Tim
I did not mean to apply that they added oil. Diesel fuel is an oil compared to avgas.
Hi Mark
Good question but I don't know the answer to that. I think it's pretty typical to have a couple compression rings near the top of the piston and an oil control ring below it, but in some engines these rings are all grouped together above the pin and others like the DeltaHawk have the oil ring way down at the bottom end. Like this: https://www.engineersedge.com/power_transmission/diesel_piston_rings.htm
Shhhh...don't given them any more ammunition. 'They' are watching us ;) 😬
