russkarnap
I'm New Here
Hi All,
Happy Thanksgiving for the Americans here!!
On the web of every bracket, there is a groove in the middle the full length of each bracket? Why? Is it normal? Do I need to grind it out of every bracket?
Sorry, I need to read up on how to include pics.
Russ
Z-brackets
Yes, it's normal. However, do some research on drilling them. There's more than one way to skin that cat.
Thanks for the help.
Thanks Guys!
Yes, these are the fuel tank z brackets. It was odd to see the groove in the middle of a bracket.
I?m going with the Checkoway/Hurlbert (sp) method. I did the first 1/8? hole (turned out to be a #30 bit though). I?ll use the 1/8? bit for the other 4 holes on them.
Thanks Again!
Russ
