flickroll
On my -8, I have the Grove streamlined landing gear. Today I fitted the Fairings, Etc. fairings between the wheel pants and the gear leg, and bonded them on using flox. My question is, after I apply some epoxy/cabo to smooth the transition between the fairing and the wheel pant, do I need to apply glass cloth over this joint? The cloth would not really be structural and would only be there to prevent a future surface crack. Or is the flox and epoxy/cabo strong and flexible enough so that a crack in the joint area won't later appear at the transition if there is no cloth applied? Thanks
