SEFlyer
Member
The RV6 we bought has a Dynon set up. It has a yellow arc on the tach from 2000-2250. I understand what the yellow arc is for and means. Those numbers are just what the Dynon install manual says to set them at. My question is does anybody have anymore knowledge of where they should really be set? It is a RV6 with 0320 with a Sensinich prop. I realize it depends on airframe, engine, prop and other factors, but curious if those numbers are close or anybody has any more information. Thank you
Prop manufacturers sometimes provide guidance on rpms to avoid in certain engine prop combinations. I would be following the prop manufacturers guidamce, not dynon’s on what rpms to avoid.
Larry
