can you use your 496 antenna with subscription to xm with your 696?? 695?? thanks.. larry
i tested another antenna on my 496 and it worked. i did this to trouble shoot my set-up which was not working. it turned out that my antenna was bad.$$$$$$$ to fix the problem.
