Becssc
Member
Patron
Heads up. I found an error that had me scratching my head for a bit. I zipped thru 10-20 and riveted in all the nutplates. Then when I got to 10-28, I couldn?t get the vertical stabilizer to fit between the aft nutplates. After much investigating, I realized the nutplates I installed were K1000-08 instead of -06. The longer length prevented the vertical stabilizer from fitting. Looks like bag 3036 has the wrong nutplates. Not sure if other bag 3036?s have the mistake. Double check before you start riveting them in!
i learned the hard way to thread every nut plate on a screw before i mount it.
keeps the wrong size off the plane too.
