Ed_Wischmeyer
Can't find the pictures of that gorgeous tool cart that had everything on the top and air tools in holsters on the sides. My search skills are obviously not up to snuff...
Thanks!
Ed
Thanks!
Ed
Hello, plans would be great, showing the tool placement etc. Since building and using it, what would you change?
This looks like an awesome project while I wait for my RV-10 project to be moved from NJ to FL.
Michael
I took great inspiration from Ron?s cart below, but not being able to find a cheap cart that wasn?t too big, I just used some left over kitchen to build mine. The drawers are very handy (they are 10mm ply), for stuff needed often but not every second. The drill bit holder and die holders are the best things ever - never have to search for a bit, and I?ve since removed some I don?t use and added reamers for an3 and 4 bolts. The air tools hang on a bit of PVC pipe with notches cut. I also now have a sandpaper holder on the side, and found 5lt olive oil cans are the best for clecos. Very handy having all the hardware boxes wherever I?m working. Thanks for the inspiration!
https://tasrv14.blogspot.com/search/label/Workshop?m=1
Back at you:
<snip...>
Don't know about you, but building my tool caddy was a lot of fun. I hope others will post pictures of their tool carts and tool boards so we can all glean ideas from them.
