How would one do that? I've got it on a switch now on the panel but I'm getting a new stick with some functionality and want to run smoke off of it. I belive it's a momentary on single throw switch on the stick.
Is this possible?
Is this possible?
Button is a momentary button unfortunatelyI have a "smoke system" switch on the RHS lower switch panel that enables the system, and a separate breaker for the pump which runs constantly. I have a SPST on the grip in the pinkie position. That energizes a relay which in turn opens a solenoid valve down low on the inside of the firewall where the smoke line runs through it. Very near the fuel line.
This setup gives me about as crips on/off as you're likely to get.
You can use a relay that switches to one side or the other with a momentary button push. It will stay on the other contact until you press a momentary switch again. Used in automotive applications. This will allow smoke to turn on with a momentary button push, stay on, and then turn off with the same momentary button push.
Latching Bi stable Relay
Can you link one that you have used in this application?
The ones I found all needed a momentary switch to ground to open, and a seperate momentary switch to ground to close. I couldn’t find a latching relay which could be switched on and off using the same switch/ground - they physically have seperate “activate” and a “reset” contacts. You could use 2 buttons on your stick grip I suppose…
Can you change the momentary to toggle on/off? Smoke on a momentary isn't optimum without a very bright, conspicuous status light. It's going to get left on our turned off when you want it on. Still need a relay regardless.How would one do that? I've got it on a switch now on the panel but I'm getting a new stick with some functionality and want to run smoke off of it. I belive it's a momentary on single throw switch on the stick.
Is this possible?
