Av8torTom
Hi, I'm planning out my wiring for my pitch servo. How are people routing this?
The wires will be coming off the subpanel.
Tom
PM me with your email Tom and I'd be glad to share photos of what I did. I don't have the portion from the servo to the sub panel done yet but planned to run through the Van's designed center hole runs......the wires headed back towards the elevator trim from the servo have been run through the fuse.
I can share photos of my 7 as well, but basically I ran the wiring down the firewall, under the cover on the forward floor (parallel to the fuel run), through the spar (at Van's approved hole locations) and along the edge of the tunnel with the pushrod to the bellcrank in the tail cone. Same routing as the tail lighting runs. Not too many wires, it was an easy run.
