brian
I know lots of RVers use various stick grips with switches. I'm using the Infinity Aerospace ones.
How are people running the wires for these? The easiest way appears to be to just run the wires out the bottom of the tube. However, at that point, several inches from the pivot points, the bottom of the tube moves around a lot. So it seems like doing it that way is going to require a lot of slack in the wire, and it seems to me that all that wire movement and flexing is going to wear out the wire soon.
The other way would be to drill a hole in the side of the stick, nearest the pivot points in both directions, then run the wires through that hole. That would minimize the amount of wire movement. However, that way doesn't seem great, either, as the close proximity of the floor ribs will make it hard to route the wires so they don't hit anything throughout the full range of stick movement.
So, how are you other RV builders and fliers doing this? Any pictures of installations would be super.
thanks,
brian
thanks,
brian
