gstone
Finished wiring my stick and wondering the best way to have the movement needed and not so much loose wire to cause a problem??? I'm sure this has been discussed somewhere but can't find the right words to search!
Thanks again!!
Greg
Here's one way.
Here's a discussion a few years ago about the subject: http://www.vansairforce.com/community/showthread.php?t=39696
Searched for this in google: site:vansairforce.com drill hole stick
If you use individual D-sub pins as a connector on the fus. side you will still be able to slide the stick grip off in the future.
Just crimp a pin or socket to each wire and and heat shrink over the combination. If a disconnect is needed just remove the heat shrink.
I drilled a hole in the side of the stick at the articulation, it's the single point with the least movement. Used one of the small plastic bushings in the hole.
