After figuring out what avionics and other electrical goodies are in the plane, what approach did you take to getting together your wiring order? Am I right in assuming it's literally a matter of figuring out where you'll place most devices, getting a tape measure out to figure out the length of runs, then looking at the wiring diagram from each manufacturer to figure out what kind of each wire you need (and what connectors you need)? Or are there any good general references people have used to ballpark things?
I've decided to use the Advanced ACM, which simplifies things a bit. Given the harnesses that they have available and the general cost of wire to begin with, I'm starting to think that I may not actually save an appreciable amount of money by making my own harnesses from scratch, but it's hard to say until I know if I'm buying 1000' of wire or 10x that amount (let alone what gauge, type, etc).
