Can someone with a 540 parts cat find the part number for a "three wire clip" for the sparkplug wires that attach on the bottom screw of the valve cover.
Sam
The three wire clamp in both Lycoming and Continental parts manuals list a regular adel clamp. I drill the hole to 1/4" and put 2 AN4-960 washers between the clamp and the rocker cover gasket.
There is a 3 wire clamp, I've used them before, made from stainless steel and a special heat resistant insert. I just can't find my parts cat to retrive the part number since my last move.
Thanks!
