Is this only happening if you are using an external unit like Stratux to feed GPS data ?
So today I took the third external ADS-B IN box up linked via wifi to WingX (the STRATUX with a current software build) and experienced the same heading issues. Disconnected the USB GPS puck from the STRATUX, and the issue went away. Next time I fly, I will uninstall the AHRS, and reinstall the GPS puck, just to confirm that is the issue.
Yes. If I turn off wifi and use my iPad's internal GPS, all is well. Likewise, per above, removing the GPS from the STRATUX got rid of the issue. GPS input from the iLevil 3 AW did not cause issues on the one flight I used it, but another poster did have issues.
Updated version is now posted
I flew with it just now and all seems well. GPS heading display seems accurate and just like before the Nov 25th release.
I am sure you have this set right but I have to ask the question anyway (sorry). Are you sure that you have chosen in the drop down that WingX is indicating GPS track rather than AHRS heading from your magnetometer? If it is set to "use AHRS" that could explain the difference.
I just downloaded the app and have used it on several flights. It?s as good as anything I?ve used. If you?re a cfi, it?s free.
Minor update - 9.1.3.3 out today - it's undocumented on their change log but it supports dark mode and minor fixes
Minor update out today
Where did you hear about that? I follow them in Facebook and Twitter and even my iPhone isn’t showing it in the updates.![]()
App Store just showed there were updates to a few apps that I have, showed up in. Oth iPad and iPhone
9.1.4.1 released 5/23
