NYTOM
I read somewhere a tip about installing a strip of aluminum around the inside of the wing tip edge to beef up the edge so plate-nuts would be installed more securely. Sounds like a plan but what are you guys using to attach the strip? I figure the rivets through the plate-nuts would be enough but what's the thought on scuffing things up a bit and using some old pro-seal to completely bond it? Has anybody tried contact cement like you would use on a Formica counter top?
