BruceEicher
Anyone find a good LED replacement bulb for the 75 watt MR16 used in Van?s wingtip light kit?
And what beam degree angle should be used if I just replace the halogen?
Thanks!
Replacement LED
I see where this thread didn't answer the original question. I have
the RV 10 wingtip kit in my 8A and am looking for a replacement
LED bulb for this installation. Without having to replace the entire
kit. Any ideas?
Thanks for this. Do you think there would be any issues using these as
a direct replacement? I use a Max-Pulse switch to wig-wag these tip
lights.
lights.
I tried a few different LED replacements from Amazon, Home Depot and on-line. A couple had so much RF noise they were unusable. The on-line ones (can't remember the vendor) worked OK after our on field electrical guru made me noise filters for each bulb. They had a small amount of noise before the filters. I use a Perihelion wig wag switch. They are much brighter with lower power consumption than the Vans Halogens were.
If I was doing it now I would go with the noise free Flyboys units which were not available at the time. FWIW.
We have a bunch of lighting options for both wingtips and leading edges.
By design our lights do not generate any headset/RF noise.
Please click the Flyleds logo to see your options!
