Ying & Yang
N941WR said:
I would like to know more about his fin
http://img515.imageshack.us/img515/4024/img3070es9.jpg
How well does that stop the fishtailing?
One down side of the dorsal fin is more surface area aft of the CG. That means landing in a cross wind you will weather vane more. Its OK, just the good old ying-N-yang of airplane design, trade-offs and no free lunch rule. It does make it more yaw stable.
Talking about ventral fins, winglets and more fins, the Beech 1900 has 8 of them I can see in this pic:
http://www.al-airliners.be/a/air france/afb-1900.jpg Ventral fins are the two long fins at angles at rear bottom of fuselage. They add directional stability. The horz fins on the fuselage must increase pitch stability. The ones hanging straight down from the end of the horz stab? I guess it adds more yaw stability during engine out since they are in the prop wash? Strakes, VG's, Winglet's, Guide vanes........all little aerodynamic helpers, but the goal is to design so you don't need little fixes. I suspect they where trying to use existing parts. When they increased the fuselage hight they needed more stability. Winglet's are the same thing, fixing a wing that just needs to be longer.
I don't want to get into winglets but I did take an engineering grad class on aerodynamics at UW from a Boeing engineer who was involved in the Boeing 747-400 winglets. Short story, like the fin above there are many trade-offs and no free lunch......... Even this aerodynamicist Prof felt the winglet was better at making a place for the airline logo than an aero improvement.
The B747-400 was a derivative airplane with an existing wing. They not only added winglets they added 12 feet span on each wing. They just could not add any more span because it wouldn't fit at some airports. Clearly the winglets do good things for some missions, but if starting with a scratch wing design you going in plan would be to meet the mission with no winglet, which adds cost and weight. The B-777 has no winglets.
JAL took their B747-400 winglets off because the way they fly, like a bus short distance, lower altitudes, up and down Japan. Winglet's help and hurt, just depends (100's of factors).
However with retro fits to old bizz jets or old airliners like the B-727/737, it may help for a new mission. These planes and wings where originally made for short haul, but many operators now use them for long haul. So it "fixes" the wing for a different mission. The BBJ (Boeing Biz Jet) comes with winglets out of the Boeing factory (which is from Aviation Partners, the company that makes the retro fit winglets). Even the variants of the B767 have seen span extensions and winglets (due to increased weight and range missions):
http://www.aerospaceweb.org/question/aerodynamics/q0148.shtml (you noticed the sheared tip....that is a winglet laying flat, which is what many aero guys prefer, if you can deal with the span for ground ops.)
Most aero guys I've talked to would rather expand wing span first than add winglets second, if there's a choice.
The little RV winglet pics are small and not real blended winglets, but if you include reducing the drag from two whip antennas its probably a gain (if you must have two more antennas). Overall no winglets (or antennas) would be a net gain and weigh less.
If you do make a real winglet that gains lift, you may have to beef up the wing or lower the load factor, which may cancel the gains (because of the extra weight). The Glasair III has a removable wing extensions. Of course Aerobatics is a no go with the span extender.
Gate space is an issue for airliners and longer wings might not fit. The B-777 was conceived with fordable wing tips! Like a Navy fighter, the idea would be the airliner would fold it's wing tips to park at tighter gates. They gave up even though a big airline was pushing it. Cost, weight and drag where too great. They Aero guys no doubt wanted even longer wings. Of course the fold idea would have to be totally fail safe and foolproof. The last goal is almost impossible to do, because fools are so smart.
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
"Gear Up....no no not wing tip up....."
