Michael Brown
Active Member
During the building process I check my wings for twist, everything was straight. Today I clecoed the skins back on after dimpling and checked again. I found about 7/16 inch twist in my right wing. I removed the skins and the tank and checked again. Now I have less than a 1/16th. Installed the tank and skins again and it remained the same. Started riveting and it is not moving. What is acceptable?
Also, I am checking this with two plumb bobs hanging on a cleco at the main spar and the measuring at the rear spar.
My left wing is perfect.
