Hi together,
my 7-wingtip trailing edges are 1/4 to 1/2" above the trailing edges of the ailerons in neutral Position. General fix is to slice the the rear edge of the wing tips and glue them back together to match the ailerons.
Well, i sliced the rear trailing edges but only the inner parts of the wing tips matches with ailerons. the outboard portion of the trailing edge stays where it was.
is it ok to slice also the side of the wing tips until one can move the entire trailing edge down? What did you guy do?
Cheers
Kay
Cheers
Kay
