sglynn
Question, how do you fasten aluminum sheets inside the wing tip cut out where position lights go? I see some of you have put aluminum on the two faces of the wing tip cutout and I don't see any fasteners. One of the plates can be held on with the light but the other isn't. Are you gluing them on? If so with what? Resin/hardner? Epoxy? Pro-Seal?
thanks
thanks
