Why?
Ditto, but gil is right the NAV is not too bad but don't count on max VOR range. LOC/ILS OK I guess.
My main comment WHY? To save the whole 1/4th or 1/3rd mph drag (at top speed) for a com antenna?
(double comm drag for a VOR whiskers.)
Consider the weight and pain of coax runs out to the wing tip.
Looks? You can hardly see a belly VHF Comm under the cockpit and coax run is short. Also you can make
it so there's inflight access to the antenna BNC connector, which could be disconnect for handheld use
if needed.
I like the VOR/LOC/ILS whiskers on the belly under the horz tail. Almost invisible if plane is white and you
use white fiberglass whips.
Performance of wingtip Com ant are poor, Nav fair, but external is going to be better any day (or night
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If I put two comm and one Nav antenna under belly. What is the best configuration as far as locations? Can
I put them all in the centerline? If so how should they be separated? Ben
You are suppose to have about three feet, but that's ideal. You can get away with much less. Why all on
center line? I'd put the transponder just aft of the fire wall on center line or just off center. Two com's on
opposite left/right side of belly fwd of spar and VOR whiskers under the tail, also on the belly, but with a
big trike like the -10 that you wannabe, in the tip of vert stab is fine. I don't like that location for tail
draggers because of eye poke danger.
