Michael Burbidge
It appears that the tie down ring is tightened by bottoming it out on the bottom of the threads rather than snugging up against the skin. There is about a 3/8 inch gap between the skin and the tie down bar. If the ring doesn't bottom against the threads before reaching the skin, then it will deform the skin. I apparently tapped the tie down bar a couple of threads too deep because the ring reaches the skin before reaching the bottom of the threads.
Has anyone had this problem? How did you fix it?
Michael-
Michael-
