This is my list from 2008 - some things may have changed but it won't be many, if any.
The first line is "Sub Kit 1" and the next several lines are the parts in the sub kit.
Thanks, Seems a few parts you use rather soon are in there.
FWIW my wing list from last week (therefore probably yours too) is basically identical to airguy's, different order but the same stuff.
I sort of hope not. I should have my wing kit on site this week, thanks to you I just noticed that mine also shows subkit 1 as back-ordered. Well, it won't be the first time I went off sequence to work around missing items. If nothing else there are a lot of ribs to prep.
