I am building an RV-7a with a Superior IO-360 8.5:1 with AFP, Dual Lightspeed ignitions, 2 alternators, etc. Since I plan on runinng mogas, I really like Frankh idea of dual Electric fuel pumps in the wing roots with no mechanical pump, and plan on doing this. The one concern I would like to address is the situation where you have one failed pump and no longer have access to the fuel in that tank. (Thinking of Alaska flying where the nearest airport may not be near enough in this situation).
Anyway, I have return lines plumbed into the fuel tanks several bays in and near the rear. What do you think of running a line with a reversible fuel pump between the supplys (or the returns) to transfer the fuel from one tank to the other? Is there even a reversablie pump that won't flow when switched off even available? I would prefer transfering between the suply lines if there aren't any issues to minimze unusable fuel. The pumping from the return should still get most of it I would think. Pro's Cons, Issues?
Matt
Matt
