Jonnyb
Evening all!
Wondering what the collective thinking is on an extra hole in the wing rib flange?
I may have got carried away with the dimpler!
Ohhh, your plane will be heavier.
If its not in the skin already, do a flush plug rivet. If its in the skin, just let me an additional rivet...Sleep may be lost over the added weight, but strength wont be compromised!
Per mil spec, the minimum rivet pitch for a -3 rivet into a dimple is .563 inches.
The reality is that it will be fine just dimpled and plugged with a rivet to nowhere. That hole is so small that you could likely be just as well off to just deburr it and leave it as is. Vans will likely tell you one or teh other of those two things.
But, any time I deviate from the factory engineering or industry standard (ac43.13 or MIL-R-47196A) I call Vans and document the answer, just so that if I ever sell this thing, I can honestly say that I have engineering coverage for anything off print.
Thanks for the input guys.
Vans have come back to me really quickly and said its not an issue and to build on!
So am off for a beer to celebrate!
Have a great weekend!
