Moeggeploeg
Member
Any builders than can share how to align the landing lights before the first night flight.
Keeping in mind the round out and flare during the landing phase.
I imagine you should back off the aircraft from the hangar door at a certain distance, then aim both lights at a spot(s) on the hangar door.
How far away from the door did you position the aircraft and at which vertical and horizontal distances did you set your landing lights? (I guess taxi lights are a different issue.)
