Hi,
About to pull the trigger on a wing kit order (slow build) - are there any items in the kit that are worth removing or anything that I should add at this point?
Some points
- I’ll be doing my own wiring - so I’ll remove any wiring etc.
- the aircraft will be IFR and with autopilot - do I need to add any items to support a heated pitot and/or the roll servos?
- I’ll likely go with flyleds as they are local
- unsure if a wing tip nav antenna are important at this stage.
- I guess a stall warning vane is not needed with AOA pitot tubes these days?
Thanks to all for your help!
Some points
