MikeJ 7A
Active Member
I'm planning to build both wings at the same time.
If I set up the shop with the wings perpendicular to my work bench it seems like that would be best in terms of work flow. But if I do that, I will have limited access (about 18") between the outboard wing ends and the shop wall. (Option A)
If I set up with the wings parallel, I will have plenty of room all the way around both wings, but it will be a "long trip" from the workbench to the second wing. (Option B).
How critical is access to the outboard ends of the wings?
![wings.jpg](/community/proxy.php?image=http%3A%2F%2Fwww.lostinspacerobot.com%2Frv%2Fwings.jpg&hash=e567f47c53cbebc5e1037fb4f7236df3)
