SpaYellowNsx
Member
Is there an internal adjustment to correct a heavy wing? I know a tab can fix it, as will as other external adjustments, but I would rather fix it internally as much as possible first-
You could potentially use the aileron trim system if installed and bias the springs to help with the heavy wing.
I would say this is a non-ideal bandaid and would encourage you to follow the directions for fixing a heavy wing. It took me 2 tries on mine and was really easy to accomplish. Unless the plane is already painted, you should go this route.
Aaron
At the top of this page is a tab for search function. Type in heavy wing and
Read .
Bill
