WingnutWick
Hello all,
I've been using the annual checklist Walt put out here and I am trying to make sure I am checking things properly when it comes to the wing spar attach bolts and the landing gear attach bolts and their respective torques. Looking through the plans I am not seeing torque values for these. The planes associated are:
RV-10
RV-8
RV-6A
Does anyone have torque values or know where to find them for all these items? Seems like the 8's wheel nuts are a bit tough to access from the inside.
Thanks all.
Hello all,
RV-10
RV-8
RV-6A
Thanks all.
If you know the bolt sizes (if you have the plans should be specified there) you can use the torque values in Van's Section 5 (Same for all models):
https://www.vansaircraft.com/service-information-and-revisions/5/
Info for the RV-8 landing gear.
From the Construction Manual:
And DWG 75 annotated:
(Check before using any of these numbers!)
