P prkaye Well Known Member Aug 8, 2022 #1 Question - is the outboard edge of the wing (the metal part) perfectly parallel to the aircraft centerline? I'm asking because I may mount a magnetometer in the wingtip and I want to be sure i use a correct reference line for aligning it.
MED Well Known Member Friend Aug 8, 2022 #2 It seems to be. I mounted my magnetometer in the left wingtip using the garmin mount and it has worked well.
P prkaye Well Known Member Aug 8, 2022 #3 garmin mount? Does this come with the GAD-29 or is it an separate purchase?
MED Well Known Member Friend Aug 8, 2022 #4 prkaye said: garmin mount? Does this come with the GAD-29 or is it an separate purchase? Click to expand... I bought it from Steinair. https://www.steinair.com/?s=Magnetometer+mount&post_type=product&dgwt_wcas=1 Last edited: Aug 8, 2022
P prkaye Well Known Member Aug 8, 2022 #5 Awesome, i've just ordered that mount and will probably mount my magnetometer in the fuselage with it. Thanks!
P prkaye Well Known Member Aug 11, 2022 #6 Actually, I'd appreciate any advice from folks on where is the best location for my Garmin magnetometer. Wingtip, fuselage or tail?
