dbaflyer
I was feeding the conduit through the rib holes which is not an easy task. I stopped after a few ribs because I noticed the conduit was almost directly above the rivet hole for the rib to bottom skin. I don't see a way to buck that rivet with the conduit in place. Anyone had this and been able to do that? I'm thinking of just putting snap bushings in there instead. Other ideas?
This picture is a bit blurry but gives you an idea of the rivet holes below the conduit.
![WingConduit1.jpg](/community/proxy.php?image=http%3A%2F%2Flh5.googleusercontent.com%2F-tdWDlHLYuQ0%2FT-pihzWHglI%2FAAAAAAAAAMQ%2FgwKhsAXjzbg%2Fs640%2FWingConduit1.jpg&hash=89c8e780f43a4faa767dc75c4b59de4e)
