rightrudder
For the final install of the wings, does the aileron pushrod get in the way of installing the close-tolerance bolts? I'm trying to decide whether to bolt up the pushrods before installing the wing, or finish bolting the wing up and then slide the pushrod in place through the tip.
I'm leaning toward using the rivet gun to tap the bolts in place, and it seems things could get crowded in a hurry in that small work space.
