skyking902001
I am about to do the final wing install and I see on several logs where -8 builders are having to use 3 washers under the nuts to get them tightened up. My question--it is acceptable to put one washer under the bolt head and two under the nut? Just trying to think ahead in case I need to torque any of the bolts on the bolt head side. Thanks in advance!
