todehnal
I need a little help from someone who can measure a wing of an RV-9.
I would like to know the chord, and the length, excluding any farings or the wing tip
Thanks in advance
Tom
124 sq. ft. per Vans RV9/9A specs.
28 ft. span
4.43 ft. chord
Now that is the span with the wingtips installed. Sorry, I can't get you the span without wingtips. Probably closer to 24 ft.
More Wing Area
I have Van's spec's on the 9. I was hoping for actual measurements of a wing: Chord, & Length of one wing, without any farings or wing tips.
But, thanks for your reply
Tom
Tom,
Measuring from the outboard to the inboard edges of the bottom skin (along the forward edge, just aft of the leading edge) I get 128 inches. Add about 5 inches for the bit of main spar that extends inboard. Measuring from the apex of the leading edge to the aft edge of the outboard top skin I get about 42 inches. Add 12 -13 inches for the aileron width if it matters.
Hope this is useful!
Perfect!
Thanks Ben. I really appreciate you taking the time to measure for me. That is exactly what I needed.
Tom
