PeteP
Does anyone produce an aluminum or preformed fiberglass windshield fairing for the 9 tipup? Don't really want to go thru the epoxy glass layup if there is an alternative available. But if I must......
I was not able to find any.
The multi-layered fairing layup (6 plys in mine) is not as ugly as it sounds. A lot of sanding is eventually required to finish, but if you use peel-ply on each glass layer, the intermediate sanding is close to nil. I dreaded the faring process and procrastinated for months, but - like so many other processes - once I got into it, it went quite well.
I agree with Rupester... I recently finished mine, and it wasn't the big bad thing I dreaded for so long. If you apply the glass layers carefully and neatly, the sanding won't be bad at all.
