Far as I know, the 6 is not discontinued, is is still available.
Here is how I understand it;
When Van decided to go with the prepunched efforts, it was a good time to update the design. It is a lot of work to re-engineer the design to include the prepunching into the 6, as well as any more changes/updates/improvements to the design. It was only a small (relatively) additional effort to make a new airframe that incorporated all the newer design elements. Thus the 7 came about.
From my own personal perspective, the 7 with the large tail is nice (less tail wagging and more authority in Xwinds) and overall I think the 7's land nicer.
I am 6' 1" with a 34 inseam. I have flown in several RV-6's and own an RV-7A. In the RV-6 with a minimum seat cushion and the seat all the way back touching the fuselage cross frame I typically have to fly with my head tilted to the side so that I don't hit the canopy. Especially if I wear a non-inner ear headset.
In my RV-7A I have at least 2" inches of clearance above my head and never a problem with having to tilt my head. That is a significant difference.
Since the -7?s are built with the match hole tooling, everything is straight; the fuselage, the wings, etc. It is very difficult to build one of the new kits crooked. Next time you are at a fly-in, notice how many -6?s have trim wedges attached to the rudder vs. the -7?s.
Besides having a higher design GW the -7 also has a higher aerobatic GW than the -6. (Any pencil whipped GW is just a guess on the part of the builder.)
To answer the OP simply.
The -7 is NOT better than the -6. It's different.
I just did several hours of transition training in a -7A and it wags its tail just like my -6A did, in turbulence.
Best,
Best,
I was in the 210th with you years ago (I was in the Murphy unit). I remeber you telling me about building your 6 and saw it once at Andrews-Murphy.
I am curently building a 7 so thanks for the time and information many years ago.
John Johnson
As a 6 owner, I've got to counterpoint this one...
I'm also 6' 1" with a 34 inseam. My rudder pedals are as far forward as possible. I use a Classic Aero leather seat with no seat pan cushions. The 7 & 9 have seat pans that are 1 1/2" lower, I believe. I have minimal time in a 7, but lots in 9's.
However, I do use a Telex headset which has ample padding. My head never hits the canopy, and I certainly don't have to tilt my head. But I must mention, that my son, who is about the same height, complained after his first ride in the 6. Turns out, his head was tilted the whole time. After getting out, we realized that the four inches of seat pan pads, that my wife uses, was still in place...
L.Adamson
If I recall correctly in the three RV-6A's I have flown in the seat cushions were minimize and the seat was all the way back against the cross bar and I still had head tilt issues. I don't know how reclined the seats were (hinge attach location) but I have my RV-7A seat minimally reclined and no head tilt issues at all. And no I don't have a big head.
If you are a tall pilot, 6 foot plus I would recommend the 7.
