Michael Burbidge
When I built my 9, the kit came with mostly nyloc 3/16 lock nuts, except for the engine compartment. My 14 kit is coming with all steel lock nuts (MS21042-3). Does anyone know why?
The bigger lock nuts are easier to work with.
Besides the small size, the steel lock nuts have a larger prevailing torque value and with more variance. I'm finding 10 - 15 in/lbs and I've had a few as high as 25 in/lbs. The nylocs were typically under 5.
Michael-
It’s a pain
Those little steel nuts suck. I use nyloc nuts..
Lock nuts
Yes certainly firewall forward steel locknuts are used. But I'm asking about everywhere else. I suppose it is weight.
Other places, there is another lock nut that will save weight.
MS17825
It's a castleated nut with a nylon locking bushing.
Might be a reduction in carrying part numbers in stock. The MS nut is approved for all locations, while the AN is not supposed to used where temps can reach above 250F.
